PH1 172 Sport
In anticipation of my braided lines turning up next week I just wanted to check that I understand how to do it!
From the search I've done I assume you just remove the old ones allow the brake fluid to go everywhere and then fit the braided hoses or should you drain the fluid first then remove them?
Also I'm assuming that if you leave the fluid in then remove the old ones then theres going to be a hell of allot of air in the lines. If so how much fluid do you normally use before all the air is out?
Sorry if some of the questions are stupid but I just want to double check everything!
