chassis set up, where to start??
Car  Clio 182 Cup
I am the new owner of a 182 CUP, and intend on doing a few track days in it, but it's also going to remain my daily driver, so I can't go too harsh with it.
Where would you recommend starting? It has nearly 90k miles on it, so I was thinking polybush the front and rear ARB (not sure on the set up of these yet) maybe stiffer/thicker ARB/s. What other bush's would you change, that can be done DIY.
I'm going to follow this up with a proper alignment session.
The brakes are horrendous, and fade after 2 or three good applications, so I'm thinking, new discs/pads and fluid. Any recommendations on what you guys are using at the moment.
Any other tips that would get me started would be great.
It's a perfectly capable car as Renault built it, however you'll have a lot of worn parts at 90k. Is all the suspension original?
I would start with springs, solid top mounts and then polybush's and if possible a whiteline rear anti roll bar
As for brakes i would start with brembo HC or MAX discs and some braided brake lines and a decent sent of pads
