B ben_p Car C63 AMG, F430 & 172 Mar 22, 2011 #1 Cup items seem to be around £150 second hand, isn't there a valver or volvo setup that fits? Any info on what parts are needed. Thinking of ditching the PAS to but not sure,
Craig.H Car clio 182 Mar 22, 2011 #4 Volvo brackets delete the PAS as well unless you modify the PAS pump/lines to run like the cup set up i believe. i use the volvo brackets, got them from an L reg 440 for a tenner, then bought myself a manual DCi steering rack for 50! job done
S sideways danny Car ITB'd MK1 Mar 22, 2011 #5 Cannit said: Can it not be done with some laguna parts? Click to expand... yes, same as the cup brackets
H h4ml3t Car A sexy one Jan 26, 2013 #8 can you use brackets from a 440 then get a shorter belt to remove the aircon and PAS?
C cmcquitty ClioSport Club Member Car 1Berg2 Jan 27, 2013 #9 Fred said: hammer Click to expand... LOL
3 3i_gaz Car Monaco blue 172 Jan 29, 2013 #10 Just done mine for about 45 quid. Cossie alt bracket, 1400mm 6pk belt and a Mercedes 6pk idler pulley. Job done.
M MG cup Car Cup In bits Jan 29, 2013 #11 h4ml3t said: can you use brackets from a 440 then get a shorter belt to remove the aircon and PAS? Click to expand... Yes, just the same as you can run no PAS on a cup with a shorter belt.
