Teratermpro + console cable?
Is there not a portable command guide for that piece of legacy s**t?
Surely its easy enough just to run a few lines through the CLI (I assume it is cli?)
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname Company
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxx
aaa new-model
aaa group server radius rad_eap
server xxx.xxx.xxx.xxx auth-port 1645 acct-port 1646
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa session-id common
dot11 syslog
dot11 ssid Company
vlan 1
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
mbssid guest-mode
dot11 ssid Company-Guest
vlan 2
authentication open
mbssid guest-mode
wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.3.254
ip dhcp excluded-address 192.168.4.254
ip dhcp pool employee
import all
network 192.168.3.0 255.255.255.0
default-router 192.168.3.254
domain-name xxxxxxxxxxx.com
ip dhcp pool guest
import all
network 192.168.4.0 255.255.255.0
default-router 192.168.4.254
domain-name xxxxxxxx.com
no ip domain lookup
ip domain name xxxxxxxxxx.com
username admin password 7 xxxxxxxxxxxxxxxxxxx
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
ip nat inside
ip virtual-reassembly
encryption vlan 2 mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid Company
ssid Company-Guest
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
ip address 192.168.4.254 255.255.255.0
ip nat inside
interface Vlan1
no ip address
ip nat inside
no ip route-cache cef
no ip route-cache
no ip mroute-cache
bridge-group 1
interface Vlan2
no ip address
ip nat inside
no ip mroute-cache
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxxxx@adsl.virgin.net
ppp chap password 7 xxxxxxxxxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxxxxx@adsl.virgin.net password 7 xxxxxxxxxxxxxxxxxxxxx
ppp ipcp dns request
ppp ipcp wins request
hold-queue 224 in
interface BVI1
ip address 192.168.3.254 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 7 interface Dialer1 overload
access-list 7 permit any
access-list 10 permit 192.168.3.0 0.0.0.255
dialer-list 1 protocol ip permit
radius-server host xxx.xxx.xxx.xxx auth-port 1645 acct-port 1646 key 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
transport input telnet
scheduler max-task-time 5000
end
