cleaning headlight lenses? discoloured and rough
  • Thread starter Thread starter jakm15
  • Start date Start date
J
jakm15
Hi, the top of my lenses have gone discoloured and rough, any ideas on how to sort this.
its a mk2 ph1 with non dual optics
Best bet is probably a wet sand with 1200, 1500, 2000 grade paper and then maybe a compound of some sort.
Meguiars scratch X may be ok to use but don't quote me on it :S
thanks, ill have a look at that scratch x, i dont want to end up making it worse, as they are plastic and easily scratched
I used 350 dry first on mine, this basically gets rid of the top layer and gives you fresh plastic.
Then I used wet sanding grades 1000-1500 and finally polished it with my Rotary with Megs #83 and #80.
After that they came up like new :)
By the way, it's really hard to muck up.
Listen to this man. I 1st tried scratch x and it was poo, ended up using megs #80 on a swirlbuster pad.
There was a thread on this lad the other week.
Have noticed that you are in the NW, quite happy to sort it for you if you bob over. I have a machine polisher so will bust through it in no time.
Very similar to this;
http://www.jmstuning.co.uk/ look under services and the "head light correction" icon.
jamie
