J
jakm15
Hi, the top of my lenses have gone discoloured and rough, any ideas on how to sort this.
its a mk2 ph1 with non dual optics
Best bet is probably a wet sand with 1200, 1500, 2000 grade paper and then maybe a compound of some sort.
Meguiars scratch X may be ok to use but don't quote me on it :S
[NickW];5313568 said:I used 350 dry first on mine, this basically gets rid of the top layer and gives you fresh plastic.
Then I used wet sanding grades 1000-1500 and finally polished it with my Rotary with Megs #83 and #80.
After that they came up like new![]()
Listen to this man. I 1st tried scratch x and it was poo, ended up using megs #80 on a swirlbuster pad.
