Cleaning throttle body
imprezaworks
Car  Mk5 Golf GTI :)
Going to do this tomo just because. Pretty straight forward? Back of the engine, four bolts and remove? Was going to use brake cleaner? Anything else?
Piece of piss mate, Lego's harder.
Unclip the throttle position sensor with a flat head screwdriver, the tab pushes in,
then undo the 4 bolts and Bobs your monkey.
Be careful not to cut yourself on the edges of the butterfly valve when you're cleaning it though,
there's a lot of tension in it and you can cut your fingers very easily.
