Climate control stuck on hot!
Car  172
As title says, climate control stuck on hot even when I put AC on the coldest setting it just blows hot air..
anyone got a solution?
Thanks.
Probably mashed the heater control gear. common issue - search for 'heater blows hot air', it's covered all the time.
Basically you want to get down in the drivers footwell, on the side of the centre console are 2 motors, one controls temperature, one controls air direction. you need to remove the metal plate and motors, put a cable tie or something around the broken cog, refit everything, and bob's your mother's brother. It's about 6-8 screws i think.
I would have thought it was the resistor pack. Is it stuck on full blast...or just full heat?
