Clio 1.2 16v not firing.....help!
  Renault clio 1.2 16v
Hi
The car was ok yesterday, I went to goto work this morning and I popped the key into the ingnition tried to fire it up and she doesnt want to play!
So after a few goes it fires up, I thought it might be just some sh*t in the fuel.........
After a long hard days work I just want to go home and see the kids and wife......Try to fire the car up again and it doesnt fire up..........again after a few mins it sparks into life...........I just want a car that works........:D
what do u guys think the problem could be?
Oh by the way its on a 51 plate
I am going to phone the local garage in the morning if it does it again.
G_F
  BMW M3 & Williams 3
Spark plugs/HT leads/ignition coil /sticky starter motor
is where i would start
  Renault clio 1.4 16v
alright i work for renault and i knoe what the truble is .. its called a TDC senor dose not cost much about £25 for the part and bout 15 mins to fit u could have a go ur self if u know where its is ..
thanks for the replies!
However, its started ok this morning, but not tonight, it took me a fair few goes....
its hard to explain, when I turn on the ignition, It wants to start, it chugs very fast......
but doesnt fire up. Where is the TDC sensor located?
Ok, I have located the sensor!
does it easily come off?
I have read that it could need cleaning.....
or do u guys reakon I should leave it to the experts..............
TDC sensor is on the fly wheel area ie down by where the engine and the box meat.
PM me your address and I'll sned you the file showing where bits like this are.
