Clio 1.2 16v PH2 MK2 Revving problem!!
  Clio 1.2 Extreme
Any help??
So basically my cars battery has been dying due to the 'Black Box' so I've changed insurance and removed the box. But whilst I had the box in i had to keep jump starting my car (This my be the problem). Anyway no i have an issue with the way the car runs... It will start normally and idle perfectly, then when I rev it the revs go up to around 1700 and stay there, no matter how long I've been out in it or how long i leave it running.
I've replaced the map sensor and the throttle body, I've also cleaned the sensors...
When is high idling, if I cover the throttle body with my hand it go back to normal idle and the same if I try to stall it.
I'm really confused!!!
Any help??
