Clio 1.2 running probs
  mk2 172
our 1.2 oasis nevew seems to want to start in a morning and cuts out a lot while trying to set off, then doesnt wanna start, runs ok at times then same again, any suggestions where to start to fix the prob?
thanks
Has
  RS 182 - Black Gold
is this a new 1.2 16v ??
if so there is a load of problems associated with these,
MAF sensor?
A good service seems to cure running problems
Or/ and give it a clean out with that cleaning stuff they sell at halfords etc along with a full tank of decient fuel (ie no supermarkets etc)
  172 cup,s2 rs turbo
a few possibilities:-
1,map sensor fault(also check the condition of the rubber pipe to the map sensor)
2,coolant temp sensor fault
3,tdc sensor fault
  172 cup,s2 rs turbo
normally the ecu faults due to water ingress and corrosion on old clios.you can visually see this if you remove and inspect the computer.
