Mk2 Ph1 Clio Sport 1.4
Hey guys, the gearbox on my mk2ph1 clio 1.4 8v is on it's way out sadly, according to the garage, at 74k. Now I won't be replacing it for a while hopefully, but in any case, the cost of buying and fitting a new gearbox is about the same as the value of the car, so my only real option is a second hand gearbox.
How long do the gearboxes on non sports usually last? Obviously depends on the driver, but is 74k around average, or a bit early. I only ask as this will give me an indication of what sort of milage gearbox to buy.
Will any mk2 gearbox fit? I assume not, due to different ratios for different capacity engines. Do I need specifically a 1.4 8v gearbox, or will others work fine?
Thanks in advance
Thanks in advance
