Yea wot kinda increase are u looking at with just the SPI changed? i know it wont be much but are we looking at any increase?
yes but the 19 and clio versions were mpi. you need the early 1.8 spi laguna.Quote: Originally posted by BUTRE on 08 April 2004
btw, was the laguna 1.8 engine the F3P??? is this the same engine that was also found on the R19 and Clio?
Im lost here.
is the 1.8 spi an energy engine aswell or is it the rsi/1.8 rt lump (which is a volvo iirc)?Quote: Originally posted by JAY172 on 10 May 2004
Im lost here.
yup i have read the right post.......... this one..........
and i get the difference between SPI & MPI
but my question was for some1 to explain to me........
Quote: Originally posted by kingJimBob on 10 May 2004
Ok im still lost here i need a defination of the difference between a SPI injection unit is and throttle bodies
Are these different things? or the same thing?
sorry for being dense but im not going to know till some1 explains to me. and the other question.............
is this worth doing in your opinion?!
and yes i have read through the whole post, but never get a striaght answer when i posted before.
lets say i have a SPI throttle body from a 1.8lag in my right hand, and to my left if my lil 1.4RT, should i borther doing the swap?!
or is it not worth doing till got the head, Ecu done etc? if i was to do them.
an energy engine is a 1.4. the rsi and 1.8rt are f engines and multipoint injection. the f engine is in some older volvos but it is a renault engine. think renault and volvo must have had some deal going at sometime as they used the f engine and renault used the volvo N7Q engine in the laguna and safrane.Quote: Originally posted by RTvalver on 10 May 2004
Im lost here.
cheers for clearing that up Jay. so im guessing the early laguna had a 1.8 E type engine then? otherwise the tb would be incompatable. in which case is it only the tb and injector system that is of use from that engine?Quote: Originally posted by JAY172 on 10 May 2004
ahhh right. yeah sorry i get you now! when you say throttle body, is it just the butterfly valve etc or is it the entire injectors and everything else that sits on top of the inlet manifold?Quote: Originally posted by JAY172 on 10 May 2004
an energy engine is only a 1.4 or 1.2. the laguna 1.8 single point injection was an f engine but the throttle body can be easily made to fit the energy engine inlet manifold. later f engines like the in the clio rsi were multipoint injection. do you get what i mean,i tend to waffle sometimes?
we used a 2ltr 8v single point injection laguna throttle body on my mates clio.
