Clio 1.4 RT .S reg "98 Sensors
  CLIO MK2 "98
Hi folks
could some kind person identify all the sensors on my Clio 1.4 RT. Mk2 S reg "98 . E7J engine ,petrol.
I have the Haynes manual which quite frankly is useless.
In particular I need to identify the Engine Coolant Temperature sensor. I think its the one with one terminal , above the temp. sender.
I tried to get a coolant temperature sensor from the renault parts dept. and they couldnt even identify or locate one on their computer for my car !
If someone has a photo . it would be appreciated.
thanks
:S :S
  CLIO MK2 "98
mines exactly the same car as yours and they cant recognise both of ours lol
I took the old sensor in today and showed them...still clueless....
I told them it should cost about £12.50 , so they ordered a sensor with that price. The other sensors were £25. This was the only clue I could give them !.
How do you test the Ohm resistance on this sensor , it has only one terminal ..... ?? If I place one lead on the terminal , where to I place the other?
I tried one lead on the terminal and the other on the end of the sensor (brass bit ), but no reading, which means its knackered or I am not doing it right, or both.!! Any ideas ???
I will buy you a beer ...........
:banghead: :coffee: :cry:
Chas
