clio 1.6 16v - smells like petrol from exhaust, white smoke. not idling smooth
Car  Renault clio s 1.4
got a 1.6 clio.
only 44k on clock, been stood for 2 years. problem is when i bought it it req new coil pencils. so it wasnt running correctly. no smoke from exhaust at all.
got it home ok. engine management light was on.
changed the coil pack, spark plugs, oil then started it up. sounds ok but noticed after about 5 seconds after start up the engine isnt idling smooth. does at first then 5 seconds later it isnt. then the white smoke starts very slight. when the engine warms up and rev it, it gets alot worse.
it isnt the head gasket as ive done a pressure test. oil is ok, water is ok.
i code checked the car as the management light was on, was a fault on lamba sensor and said overfueling. but ive cleared them. but still smoking and hasnt come back on
can anyone help me please
Could be a fault with the radiator, had the same problem with the tele boom fork lift truck at work and we had companies in to change head gasket and pressure test it and when they got it into the work shops finallyyyyyy ! They found a fault like a crack or deformation on the radiator,
Hope it helps .
yeah, just cant see it been the radiator........... its more engine management or sensor telling engine to over fuel.... plus dont know what the smoke is all about.
checked your oil level? Pull the plugs and check there condition... you're looking for signs of oil contamination.
Mick
If it's been stood for two years there is probably a load of water condensed in the exhaust which will be boiling off once it gets warm as white smoke. The petrol smell is just normal on start up.
umm. it been running for at least 3 hours in total and the same. its not the head gasket. ruled that out.
