Renault Clio 1.8 16v
				Alright so my clio is finnally on the road. Ive been under the car more times than i can count over the past weeks, managed to problem solve along the way but theres a problem with the idling
Once ive gone over 4000rpm ( roughly )
The rpm will only drop to 1500 not to the 1000 its supposed to, any ideas?.
Ive changed
lambda sensor
Map sensor.
Cleaned icv
Im really unsure as it wont drop back down to 1000, unless the engine is turned off and started again, as if it resets itself ive no idea.
Theres also a post on a different forum which sounds like the same issue but there was no fix:
https://www.honestjohn.co.uk/forum/post/index.htm?t=56018
Ive changed
lambda sensor
Map sensor.
Cleaned icv
