clio 172 miss fireing please help???????????
  clio 172
i have just bought a clio 172 waz running fine then started missing engine mang light started flashing and car running very dogish so put it in garege they said ht leads and plugs fin £101 later had car back running fine now 35miles later same problem put my freinds code reader on it nothing showed up:mad::mad::mad:
has any1 got any idea wot to do now dont fancy putting in garage again.......
  RenaultSport Clio 172 FF
Try the bolts holding the inlet manifold on, mine was loose and behaved like this cos it was sucking in too much air.
  Chav Rocket
have you taken it back to the garage?? your £100 out of pocket, you took it in to get a fault fixed and its still there.
If you search the technical help section you might get some ideas ;)
also there are lots of specialists on here, you be better of taking to one of them if you cant solve the problem on your own.
