Clio 172 mrk2 phs2
Car  Clio 172
Just wondering if anyone could give me a full list of all the spec's of a 172 mrk2 phase 2, i.e cliamte control, does it have 6 disc multi changer, mpg, and perforance sats would be good to. Cheers
Specs for the 172 can depend on the year as to if whether it got swichable ESP/traction, cruise control etc.
Climate control was standard on the phase 2 172 proper.
Taken from Edde's post in the members only guides section - well worth joining up as a full member for the info in there.
Phase 2 172
The phase 2 cars first came out on a Y plate many were dealership or test cars on this plate though.
Differences were the use of the phase 2 body shell, interior etc also engine was changed to a drive by electric cable type (engine code F7R 732). Later versions of the engine used the turbo head casting which isn't as good but the engine code and power output officially didn't chnage. UCH computer to control all the cars electrics was also added and the gearbox was also changed. Reduced gearbox ratios were used to help keep the 0-60 speeds etc the same since the phase 2 172 weighted a fair bit more but had no more hp.
Also the front suspension was change different redesigned driveshafts etc were used but the spec is similar. (see here for the details of spec changes????????????????????????????????)
The CD changer was changed to an optional for £300 then added as stock spec then later removed again (when crusie became stock spec). In the phase 1 it was standard. Most people took this option up but if they didn't the CD changer cable won't be there if it is there then the last owner has taken the changer out but not the wire. However the wire is £86 from Renault and they are the only stockist.
About mid 2001 though the gearbox was changed the speedo sensor was removed and the speedo input comes from the ABS system. The ratios remained the same.
On about mid 2003 models ESP was added. On later cars a button apeeared to turn it off it appears on the drivers ride hand side near the traction control button. It can be switched off and if it is a little triangle appears on the dashboard with a car sliding about inside it. If its left switched on (it always defaults to being on) if it is operating then the triangular light with a picture of a car sliding about appears. Some people like the system others don't. For track work most people switch it off. Some switch it off all the time.
On later 2003 models also cruise control and speed limiter was added. Its easy to tell if a car has it as there the extra buttons on the steering wheel itself.
Also clear side repeaters were put into production about 2003. (from orange)
There were foreign special edition cars made notiable the PS2 version although I've no more information on spec so its unlikly to be any serious changes.
At about 53 plate a cost saving measure to remove the door locks was done. SInce the cars are French and legally you only need one lock on the doors they remove there passenger side door. In the Uk we had to live with the fact we drive on the other side of the road they weren't going to go make cars with locks missing on our drivers side.
The cars came in unique colours only seen on the RS Clios.
Flame red paint code B76
Monaco blue paint code 432 pearlescent
Iceburg silver paint code 640 metalic
Pearl black paint code 676 pearlescent
Options on it were
Sat nav
CD changer
Telephone preparation.
The wheel style is known as Alyum
Interier is known as Dark Grey Perforated Leather / Alcantara TC3
