clio 172 replace starter motor
Possible without removing exhaust manifold, but it's fiddly.
Airbox out. Battery out, upper inlet manifold off. Sm heatshield off.
13mm copper nut holds the loom to the SM. Also a tiny spade connector.
3x 13mm bolts at far side of the gearbox hold the sm on.
Should wiggle out.
Trickiest bit is getting the heatshield back on tbh.
Should wiggle out.
if you take the wheel off ,jack it up.. may help to put shield back on.(make sure car is secure)
