Fishfire
Clio 172
So, I've been trying to set the boost on my 172 turbo, but I can't get it to stop spiking.
I've tried two types of manual boost controller (ball & spring Dawes and Atomic bleed type but each resulted in the same spike and inability to make and hold peak boost.
If I increase the boost through either controller, all that happens is it spikes higher but still settles down to around 6psi give or take.
I need to hit and hold 7-8psi
The turbo is a maxspeedingrods replica 2871. These are known to have much smaller wastegate ports than the Garrett's they're based on so I ported mine out prior to fitting to avoid spikes.
The only thing I can think of is the wastegate actuator itself.
It's an adjustable type with a '5psi' spring but in reality is more like a 2 or 3psi spring.
I'm wondering if a heavier spring in the actuator would resolve this issue?
It's got me scratching my head tbh 🤔
