Did a lot of research before attempting this on the passenger side headlight, some said remove the bumper, others said it could be done without. I'd suggest to anyone about to try this to remove the bar! With the electrical box right behind the lamp it's almost impossible unless you've done it a few times before. Removing the bar was very very easy, and there's a great guide on here too.
During my 1st attempt with the bar still on I managed to snap the piece of plastic between the internal lamp holder and the external hex key adjuster. Now the lamp assembly sits loose inside the headlight case, probably pointing in the wrong direction. Does anyone know if this can be accessed to repair, or is the whole light sealed with no way of opening it? Heat gun?
Also, changing the lamp didn't work, so now I will turn my attention to the ballast. Has anyone ever changed the lamp, the ballast, and still had no luck? Driver side and all other lights work fine.
Cheers!
Cheers!
