Clio 182 beeps like crazy when i reach 80mph
  clio 182
As above I've just bought a Clio 182 when I drive it its fine. As soon as it get to 80mph it beeps. I'm sure it's the dash that beeps to say I'm doing 80 mph but I'm not sure. Very random. Anyone know what this is or if I can stop it. Thanks in advance.
  172 Cup & K20 Ph1
Speed limiter setting? Check the switch on the right hand panel under steering wheel. Likely set to 80 and giving you a warning
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Its an option called "overspeed" iirc amd needs to be set to off/on in CLIP
  clio 182
Re: Clio 182 beeps like crazy when i reach 80mph.
Thank you very much for your replays. I will check the first comment then if not will try clip. Cheers.
