Clio 182 ff set up
  clio182, defender
I have a 04 plate clio 182ff and was wondering what suspension set up it should have a standard. should it have cup springs and shocks or should it have standard sport suspension. also could some one point me in the right direction for the right wheel bearings for it please if possible. thanks in advance jeremy.
  Clio 172, Escort RST
Cup Springs and shocks should be on an FF.
Which wheel bearings do you require? For the fronts OE branded ones from ECP should be ok from the likes of SKF etc but the rears are part of the disc. I understand that Renault are the best people for this if you wish for the bearings to last any length of time.
  clio182, defender
Is there any way I can check what suspention it should have is there any different fixings or spacings for cup and non cup? Also Front wheel bearings are what I require. Are there any good ones on eBay. Also is there any specific coolant that should be used?
