RB Clio 182
				Hi guys,
First post here. I have recently got a RB Clio 182 that has intermittent starting issues.
Symptoms are:
- Fires up fine when it is working, can drive for any distance no problems at all.
- When you go to start it again, you hear a relay click in the passenger glovebox area but no crank at all. Totally dead.
- Can be bump started, so leads me to believe the problem is not immobiliser / reader / key related?
- Battery is brand new and tested.
- Alternator is brand new.
- Can't jumpstart when bypassing earth to engine chassis.
Called breakdown today who are convinced it is the starter motor and want to replace it - but I am not sure based on the fact it works faultlessly when not having this problem. I am thinking it could be:
- Starter motor
- Earthing?
- Crank sensor - would this cause a no crank situation?
- Loose wiring in fuse box / faulty fuse?
Done a lot of reading on here but curious to see if anyone has had these exact symptoms.
Many thanks
Symptoms are:
- Starter motor
- Earthing?
Many thanks
