Clio 182 Rear Left ABS Sensor, Which One?
Car  182
That eBay one will 100% not work. The OE Renault part no is 6000073527 and is £115 from Renault parts direct but I sourced a blueprint OE spec one for peanuts.
Leave it with me...
Thanks, got a pair of fronts off eBay for under £40 so was surprised I couldn't find the same for the rear.
I tried both from ECP and neither fitted. 1st had a different connector and the 2nd had the correct connector but when fitted it block one of the hub bolts. Ended up using renault parts direct.
ATE 24.0741-1129.1 is what's stamped on the one I got from Renault parts direct and here it is on Amazon for £30...
https://www.amazon.co.uk/gp/product/B0068MHC8M/?tag=cliospnet01-21
Interesting, the 1 I removed is an ATE 10.0741-1129.1 but this doesn't come up with anything on google. I wonder if the first 2 digits control the issue level.
Can I confirm yours looks the same as the 1 below?
http://www.ebay.de/itm/ATE-Radsenso...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
