Right I've tried all I can to eliminate this misfire and horrible noise but I still have no idea what can be causing it.
Things I have changed:
Injectors
Spark Plugs
Leads
Coil Pack
Cam position sensor
It also has a brand new Dephaser.
The car is running 438 catcams and has a map on it from engine dynamics. The map was originally put on a different engine which I have swapped out as it wasn't making good power.
Anyway onto the noise:
As you can see the noise doesn't happen when you rev the car up slowly, only when revving fast.
Definitely sounds mechanical to me but surely the engine would have eaten itself by now. Other ideas are rattling tensioner.
Anyone got any ideas?
Injectors
Spark Plugs
Leads
Coil Pack
Cam position sensor
