You can sort that problem, I had it on my last 182.
Mind explaining how? Thanks
I'm honestly struggling to think of anything...
If there's a way of flashing your lights when they're on I've yet to work it out. That really winds me up. I just wave at people these days.
Steering wheel, as it's huge, and melts. Seating position is far too high. Runs like crap from cold.
Yeah, if you move the light switch to on, it's possible to flash someone without them staying on like when the switch is "off" but the lights are on.
This is the reason i think auto lights are pointless.
People who own them,then do nothing but b**ch about them.
So you think auto lights are pointless becasue it stops you from doing something your not actually ment to be doing anyway (according to the highway code) :S
I'm not on about transporting sofas, just general lack of cubby holes and a tiny gloveboxLack of storage space lol get yourself an estate if you want storage space
You ought to try going on top instead.Feet getting stuck under the dashboard. I'm only a size 9 FFS.
It's French.
Sounds like you have a bad one.The standard 182 Cup wipers.
The click from the wipers(relay) when on intermittent.
The cruise control not allowing me to select some speeds(ie 30mph is probably the most annoying(it's either 29mph or 31mph). Also no 45mph, 48mph, 50mph and a few others- can you tell this bugs me).
The alarm beeps sometimes(3 times- mostly when parking at work).
The initial body roll on turn in.
Useless standard brakes(on mine at least).
Not so great damping over small "stuttering" bumps(I can feel the dampers packing down), which leads me to...
...The slightly over-sensitive throttle pedal when cruising- bumps can cause me gain or lose 10mph without wanting me too(tiniest movement by my right foot).
Backend feels a bit floaty.
Other than that- its the usual Renault stuff that I knew about before I bought it.
Steering wheel and a cold engine!
Ok,I also have a Cup and don't recognise most of those symptoms.
