Clio 200 - anyone running a raised limiter?
Martin_172
looking at my RR graph from yesterday, lets not use this thread to dispute results etc but by looking at the graph its self, the car hasn't started to tail off even by the rev limiter, so looking at it i recon i would benefit from a few extra hundred RPM
thoughts?
Uploaded with ImageShack.us
I'm sure when my 197 was mapped the limiter was raised by a few hundred rpm, it then had 30,000 hard miles so can't be too bad. Probably worth doing ARP bolts if your going to give it some abuse as from what i've been told the standards are the weak link at high RPM
I think you are mentally fcuking insane.
HAven't you had enough problems??
I think I know what I'm saving for when my car is looking nice on the outside :approve:
And doesn't that graph have bhp as well as torque? As stated in the legend?
TDF stage 3 is looking appealing, whats the crack with the flat spot on aftermarket exhausts is TDF able to map this out these days?
I thought you only gained the flat spots when de-catting? I haven't read anything yet about being able to map it out yet, maybe wrong :s Graph looks good, is your motor standard?
cars now finally running good, just going in this week to finally get a dodgey caliper replaced so it finally brakes in a straight line again, then it will be running sweet! never to be returned to arnold clark ever again! f*****s!!
