AndyBMX
Golf R
Hi All,
Hoping for some guidance with an issue I'm having on my 200.
I've owned the car since October and over the last few months I've noticed that my brakes are getting progressively worse. When braking there is a fair bit of travel in the pedal and no real bite, and if I come off the brakes and press them down again straight away, they work better but again there is no real bite as there should be. I basically have to double pump the brakes every time I slow down.
I initially thought this would be air in the system but I've had the brakes bled and apparently there was no air in the system. Does anyone have any ideas on what to check first? I thought about having the calipers rebuilt to see if there was any issues with the pistons etc, but thought I'd see if anyone has any other suggestions before I do that. The fronts disks/pads were replaced at the end of 2017 and the rears were done mid 2018.
Thanks in advance.
Thanks in advance.
