Clio 200 rs 2011 exhaust manifold.
Car  clio rs200
Need some help with finding a good after market exhaust manifold for my RS200 mk3 2011.
It has blown on the flexi part of the manifold, my garage seem to be struggling with finding a part to fit.
Has any body got any recommendations for a
Direct Replacement.
Thank you in advance,
Michael
Easy once the manifold is off if you can weld!
Cool, only ask as my garage mentioned about cutting out and welding a new flexi in. But they said as the sub frame has to be removed to gain access you might as well fit a new manifold.
I can Tig weld but not sure if getting the sub frame off is beyond me at home.
Thanks again
So what is the minimum you need to do to install a new Gravity Performance manifold including the flexi joint ?
It’s not too bad. Maybe a dozen fastenings or so, but they’re big and quite tight. You’d need a big breaker bar.
The annoyance is technically you should then get the car aligned afterwards.
