Clio Cup 172 - limp mode
Hello all,
my friend has bought a 172 a few month ago, he has come to me this week saying its started to misbehave, as he knows nothing about cars
On occasions if he takes it over 4k-5k the light on the dash that looks like a heart monitor (i think this is the engine mangemnt light?) comes on and the car has no power and will not rev passed 3k revs until you pull over, turn the car off and back on again (resetting the ECU i would have thought)
Now to me this sounds like its going into limp home mode because its registering a fault
i drove the car and it didint seem to be misfiring, and it let me drive it quite hard for a while before it went into limphome mode, pulled over turned it off and back on again and it drove fine again and pulled to redline
My feeling is that it a problem with Spark plugs, leads, coil or O2 sensor
Any body know of this problem?
to me
That is the car going into limp home mode, you need to get it to a garage and stop thrashing it to the red line, why would you thrash a car when its clearly not write? Correct me if I am wrong.
Because the problem is intermittent, and we where just trying to replicate we he did when it came on
as the car drives fine and has full power before it gos into limp mode
i wouldnt call taking it to redline once thrashing it
My post may of come across that i just jumped in the car and cained it, this isnt the case, i have owned various performance cars one being tuned Skyline GTST so i do know how to look after a car
Bigchris had a similar problem in his 172 cup i think it turned out to be a dodgy throttle sensor or something like that.
Kewl, cheers buddy!
Interesting stuff its done £60k miles and dont think its ever had the plugs changed, so i am gonna put some new plugs in for him as its the most inexpensive things and needs them anyway
If the problem carrys on ill send him off to get diogs test done as there seems few things it can be
cheers
mine was the same the other month, needed new throttle body. try this drive in 5th gear at like 40mph, push your accel pedal hard to the floor, and i betcha it goes into limpmode. coudl try changing the pedal pedometer (i did that £69 renault inc vat) btu that didnt' fix mine, broguht new body and its fine, ruchs much better with new one. my old one had done 85k
I'm having the same problem with mine.
In the garage at the moment as was a problem with the throttle bodies!
Just to let you all know
I changed the plugs for him, just put some bosch super 4's in as they have always been a good plug 4 me
And problem as gone away! so hopefully it was just the plugs
cool, did you replace any inlet manifold gaskets or just re-use the old ones? think im gonna change mine this weekend as its started getting worse
I'v had my plenum off about 4 times still on the same seal no problem, seems a bit wasteful getting a new seal everytime if there is nothing wrong with the old one.
They hadnt gone hard or flattened so just reused them
All's been fine
Hes also got a really nasty cheap ebay special Intake cone that just flaps around on peice of flexi tube,
Any suggestions of a good intake cone to replace that POS ?
