Clio Cup Geometry
Car  clio sport cup
I previouly had a Honda s2000, and setting up the geomety (not the tracking) was critial to the cars handling.. A simple tracking setup would not suffice to get the correct setup.
What is the correct setup (maybe for different applications, road, track) for a phII clio cup?
Only adjustment on the back is by using shims to adjust camber. Front camber is done with camber bolts. Standard front camber is -0.5 degree. Track use, anything upto -3.0 degree.....from reaading on here.
