hear you go mate. i had the same idea.
New Clio Cup Technical Specification
Chassis
Steel monocoque, Matter bolted roll cage
Aerodynamic features: Diffuser and rear spoiler
Engine
Layout:
Type:
Bore x Stroke:
Power supply.ignition:
Max power:
Max torque:
Max engine speed:Front transversally mounted
Renault F4R RS – four cylinder – 16 valve – 1,998cc
82.7mm x 93mm
Magneti-Marelli built-in management system
151kW (205bhp) at 7,300rpm
223Nm (22.7m.kg) at 5,550rpm
7,500rpm
Transmission
Type:
Gearbox:
Gearshift:
Differential:
Clutch:Mechanical
Sadev six-speed sequential gearbox + reverse gear
Steering-wheel mounted mechanical control
Limited slip (discs and rails)
Single disc
Axles and suspension systems
Front:
Rear:Steering axis suspension, Bilstein shock absorbers, H&R springs
Programmed deflection, torsion beam suspension, Bilstein shock absorbers, H&R springs
Brakes
Front:
Rear:
Brake pads:
Renault Sport recommendation:
Wheels:
Tyres:
312mm diameter ventilated discs with Brembo four-piston callipers
300mm diameter solid discs with Brembo callipers
Brembo
Ferodo DS 1.11 (front) and DS 2500 (rear) cockpit adjustable bias
Speedline 8" x 17" one-piece aluminium/magnesium alloy wheels
Michelin 20/62-17, S9B (slick) and P2C (wet)
Dimensions, weight and capacities
Length:
Overall width:
Height:
Wheel base:
Front and rear tracks:
SCx:
Fuel tank:
Unladen weight:3,986mm
2,025mm
1,480mm
2,585mm
1,538mm and 1,520mm
0.77
54 litres
1,060kg
