Clio cup racer owners!!
Car  Clio172cup rally car
Just wondering if the oil pressure sensor are temperamental?
I've recently fitted all the cup racer loom to my rally car after fitting the sequential and I keep getting a oil pressure warning up on the dash, I know the engine is fine and there is plenty of oil pressure there( well there was just before I took the engine out)
spoke to rsport today and they have one in stock at £35 which isn't so bad, but before I go buying one just checking if this is common problem of them breaking
I have one you can borrow if you want to see if it fixes the problem just in case it's not that at fault
Cheers Ian :), started it up today and it wasn't giving any warning which is wired! maybe it is on it's way out!
Also I wanted to ask you about the vibrations in the car with those solid engine mounts? I can't believe how much everything shakes, I've never been In anything with completely solid engines mounts before, felt like my teeth where going to fall out! It's that normal lol
Yes it vibrates quite a bit , that's the noise you can hear on my in car video's
