Clio DCI shift pattern
Ok im after a silver gear knob insert for my 1.2 16v........I have found one but its coming off a 1.5 dci, do they have the same shift pattern as the 1.2 16v, is reverse in the top left hand corner (lift up).
Cheers,
Alex
Abit more reaserching and it appears that reverse is bottom right in a dci, therefore this insert would be no good to me..
i learnt in a dci 65, it was an 05 plate car, and the reverse on that was top left.
not sure if that helps?
Its the dCi100, they don't use the same gearbox as the rest of the range hence the reverse in the bottom right. All the others use a J series box with the same gate as your 1.2.
Where is it? If its at a scrappy you should have just put it in your pocket, thats how these things work. ;)
