Clio II (RS 182) rear spring seats
  Twingo RS Cup
Greetings,
I bought Cooksport springs for my Twingo RS a month ago and fitted them. Since these springs are essentially the same as Clio II RS ones, the stock Twingo RS rubber spring seats were slightly too small to fit on the springs, hence I fitted them without the rubbers. Recently it started clicking when going over potholes and speedbumps and I don't like the metal on metal sound so I'd like to get some protection. Here are my questions:
Are all Clio II spring seats the same or does Clio II RS 182 have different ones?
I'd kindly like to ask someone for the item codes (Clio II RS ones) for those rubber spring seats (left and right, top and bottom - that is if the codes are different)?
Hope someone can help me out.
Kind regards,
Matija
  Clio 2.0 16v 182
All mk2 clios have the same rear axel so, yeah the rubbers will fit no matter what variant they're from. Give the springs a check over when you instal the rubber seats. Chances are they've been scratched up pretty bad and if that's the case you need to paint them to stop them rusting.
  Twingo RS Cup
Thanks for the info, I'll give them a check as soon as I get the rubbers. Any chance you could tell me the item codes? I can't find them anywhere.
Kind regards
