Clio leaking
Car  clio sport 1.2 16v
My Clio is leaking from the top of the drivers door. The front drivers footwell is a little bit flooded but behinded the driver seat footwell is full of water . I no its coming from the top of the door because the ceiling is all damp. Any ideas on how to fix this problem?
Seals all ok?
Has someone tried to break in and bent the top of the door? Try bending it back so the seals work again?
mine did this, was one of two things, the sunroof leaked and the drain pipe was clogged.
my drivers door had to be re'aligned so the to had sealed properly.
not had wet carpets or headlining since
