Clio main beam not working
On the wifes 1998 Clio 1.4 (facelift model) the main beam doesnt click on when the lever is pulled back, although it works in flash mode (so if the lever is pulled back and held, the main beam comes on) but doesnt seem to "click" into main beam position like every other car ive had! any ideas lads and ladies?
Cheers, James
are you doing it with the other lights on as well ??
and also with the car running?
i know on some cars you cant keep them on unless the other lights are on or car is started give that a try.
If not sounds like you have a faulty stalk lever.
should be about 3 screws under the steering wheel
top shud then pull off.
stalk will either be clipped in or screwd into place with a retaining screw.
Wont be that hard to change.
