new member here with a quick querry , i hvae purchased a mk3 clio and have noticed a metalic clic every so often when i press and depress clutch pedal.
Any ideas what it could be clutch still works fine not slipping or anything at all
Our tCE does it and I've had loads in for various services that do it to. Ours is the clutch position switch and some silicone spray normally stops it for a month or two.
Just remove the switch from the pedal assembly and see if it stops. If so either replace the switch or do what we do and keep lubing it.
