Clio mk1 central locking ir sensor replacement
Chocice
  172 Cup
I have a completely dead ir sensor board (near the cabin light) but my key is fully working, I wondered if anyone knew if I buy a second hand board from say another Clio or same era R5 would it work as there are some for sale on eBay. Thanks
16v_paddy
  Valvers & 172 Cup
Bit of a minefield this 1 is, depends what phase car yours is and what ecu you've got because the wiring differs slightly between them.
As a rule of thumb, the IR sensor itself isn't paired up to the key (it's the bits after the sensor that are apparently coded together) so you should be able to get 1 from another car and it will work.
I've tried 5 or 6 different sensors on mine & they all worked with the original key but that was a Ph2 car with a ph1 ecu. But I have read that others with different combinations had different results, so it's a bit of a gamble. As long as they're not ridiculously expensive just send it & see how you get on
Chocice
  172 Cup
Ok thanks, mine is a late one (p reg) making it a phase 3 I believe, the options on eBay are ir sensors or the ir sensor and key so I was thinking the key was linked to the ir sensor.
16v_paddy
  Valvers & 172 Cup
Oh, if it's phase 3 I aint got a fcuking clue what the frenchies did or didn't do with the wiring in those :ROFLMAO:
RichValver
  Clio 16v/172 daily
I tried a couple of spare receivers on my ph1, None of them worked. They could just have been faulty though. (My original works fine)
Chocice
  172 Cup
I just bought one from eBay so I’ll let you know if it works, and thanks for the seat buckle RichValver.
Chocice
  172 Cup
I took a gamble and bought one off eBay without thinking to much about it, now I have received it I realise i have a far more sophisticated board (green is mine and brown is an earlier version).
Brigsy
  T.Turbo
I have a couple of keys and receivers in the garage out of mk1 clios. They are poss paired up but i cant remember 100% as had them for years, no idea if working or not. I was going to ebay them off but if your interested give me a shout.
Chocice
  172 Cup
Would they be the green pcb style?
Chocice
  172 Cup
Terrific, I’m going to get the board re soldered by a specialist if that doesn’t work I’ll let you know Brigsy
Chocice
  172 Cup
The problem was the car had been sitting with a leaky sunroof so I guess it corroded the board
RichValver
  Clio 16v/172 daily
I think the brown ones might be r19? I just had a look at my spare ones. One was green and one was brown but with slightly different ir cover to the clio one
Chocice
  172 Cup
I was looking at some French forums regarding these modules and the early boards went in various cars, it seems like even the early ones couldn’t be swapped out without the correct fob as the ir frequencies where different to stop you unlocking an entire row of Renaults in a French supermarket car park. They work in the same way all you’re seeing is a more modern set of capacitors. I believe the ir sensor then sends a message to the car’s onboard computer but I’m not sure really whats going on, there must be more too it then simply seeing a basic ir signal from a key fob and then unlocking everything surely.
Chocice
  172 Cup
I`ve had a mid repair photo come back from the PCB repair guy, it looks as though over time the contacts on the board themselves have dissolved.
