Clio Mk2 front wiper mechanism - a head's up
Darren S
I thought it worth mentioning as I've fixed the small issue on with my front wipers today.
Although there's the obvious three bolts holding the mechanism in place, there is also a metal spindle at the rear of the bulkhead that helps locate the whole assembly in place before putting the bolts through.
Clearly I hadn't alinged this before and the sweeping motion was a bit off and the motor a little noisy. Definitely worth checking if you have to remove or replace your wiper assembly.
