Rolls
Clio/ EscCos
So.. Bit of a general question for all of you guys..
I've recently bought a 182 - essentially a blank canvas if you will.. Belts will be done shortly, and I'll be asking the garage (two techs) to give me a list of stuff that needs attention..
My actual plan for the car is to essentially keep it as a fast road car that's suitable for the occasional track day (with a list of what I intent to do further down..) and this leads me to my question for you.. If you could start over, what would you still do.. What would you change. And, most importantly.. Where would you stop?
My plan is pretty much as follows:
Ensure the engine is healthy and do the following mods for 'power' : cat back exhaust, and air filter.
Change the engine mounts / gearbox mounts - assume vibratecs (or equivalent) are suitable
Brakes : go to the brake man on here (I can't remember his user id!) - rears all replaced with new items, front updated (standard sized) discs and pads, and new hoses. Obviously flush the system and replace fluid.
Wheels - get some turinis, and some half sensible track suitable rubber that's still ok on road (any suggestions?). Ensure its all tracked as it should be.. Camber bolts worth looking at?- which leads me to...
Suspension : replace all of the bushes with power flex items. New (standard) shocks and cooksport springs. New lower arms, track rod ends and ball joints too.
Interior - retrimmed steering wheel, 2 buckets, 2 harnesses and a cage (although it will only be 1 bucket seat in the near future - the rest can wait!
So.. Over to you!
So.. Over to you!
