Yeah I should've kept that shorter really, ignore all that this is all you need to know - Ph1s are better.
lol cheers just wanted to know as its my first clio lol and i do agree they look miles better.
with more castor does that afect any thing on the front end?.so i take it the ph2 172 and 182s are the same just diff engine.
need to build my knowledge on them
All mk2 2.0 Clios are F4R, the ph1 has bigger inlet valves, the 182 has a different manifold and all have different inlet manifolds.
The later ones have more castor so that means a touch more stabilty and a touch more camber when cornering so you can run less camber static for better grip. One of those mods that I won't do until I was replacing the wishbones anyway.
Have a read of various threads, a lot of knowledge on here so plenty to research!
but that vid you put up then says alot. is that your car.
Also Ph1's have ABS and air con and 172 cups don't hence why women drive the phase 1's
Lol, people who buy cups are just ASW's
