i have the standard round shaped air box with the oe cone filter element,its due a change should i go for a induction kit or is there a performance filter for the oe air box?
yeah just had a look on there couldnt see a ITG filter for the ph1 172 though,my mate works at pipper x and thay do a replacement element but are thay any good? also thay do cold air feeds but only 50mm 65mm 75mm and 100mm,what size should i go for? thanks again.
Remove the airbox, original CAF's (they're bolted on at the bottom so take
off the arch liner to get to the bolt) feed in the new hoses.
Refit everything and enjoy.
Route the hoses down behind the bumper / arch liner where ever you see fit, the lower the better but not so low it sucks up spray/dirt/dust from the road and not hanging out the bottom of the engine bay lol
I used 70's but they're too big so 60 would be spot on I think. They're made by Green, same people that do the green cotton filters, about £13 iirc, should be able to find em on demon tweeks or various other sites. Cant remember where I ordered em from now
It was a meter long so I streched it out and cut it in half, no need to buy 2 of em
perfect... just the guide i needed.
gonna try find a filter next weekend and get it fitted. Only really have a choice of k&n filters here tho, the cloth and mesh type, we dont really get the foam type filter you have in that pic.. is that a bad thing??
