Clio Williams 1
I have a few electric niggles with our Clio Williams 1. Gives impression of single click as though starter solenoid is faulty occasionally it fires up and can bump start if required.. SO far I've replaced/checked the following:-
1. Starter motor replaced with 2 new ones and old ones bench test ok)
2. Replaced earth strap, no earth fault though check by connecting battery and gear box with jump lead and fitting new earth strap as a matter of course.
3. Spade terminal wire on starter felt slack so renewed that.
4. Checked battery ok and fully charged nearly new.
5. Checked all battery / starter connections are tight and corrosion free.
Does anyone have any suggestions on what could be wrong? I was going to check the ignition switch and I Believe there's a block behind the glove box which can corrode?
Is anyone from around West Yorkshire that has experience of these problems who might want to look at fixing it (will of course be paid!)
