Clio Zig Zag & Coil light on & off when reverse!?
Car  2001 Clio Sport 16v
Heya all. So the other day I drove home from work and to go on my driveway - as it's a tight turn - I drive down the side road a little, then reverse up & turn, then drive forwards onto the drive. When drove down the side road that night, I noticed the Zig zag & Coil warning light come on in orange. When I put the car into reverse, it turned off.
I thought it was strange its not done that before.
So I left it and I've been to work again tonight. Everything fine on the way. When I started driving home after filling up at the garage, the light came back on again. It drove home fine with it on.
As I drove down the side road again, I put it into reverse and the light went back off...
Could anyone help me with what the issue could be and if I will be ok driving it still?
Thanks in advance
Bex
On the 1.2s there is a bit of loom that chafes and eventually shorts out - bring on the aforementioned 'heartbeat' light. Could be this and when you put it in reverse, the loom is pulled away from it's short a little.
I think this can cause it to run roughly too - hence the coil warning light. I believe it rubs around the ECU metal cover, near your battery.
It might be worth having a look to see if the wires have rubbed through, if they have, make sure you re-insulate them with some fresh tape, nice and thick so it doesnt wear down again.
