clio16v with willy engine
C
chip16v
Ive just put a deposit down on a complete willy engine(wiring loom, ECU and starter motor included) with 70k on the clock. The price agreed was £650, do you think i paid to much or is that ok. I know the engine should just drop straight in but will it run alright if i just plug the williams ECU in or will i need to get the ECU setup at hill power or somewhere.
  ExigeV6|Q5|DS3|Fiat
As long as the engine is ok and you are using the whole willy engine, the williams ecu will be fine
yeah its a good price for the whole engine.
C
chip16v
another question i have is i planning to use the williams manifold and iam going to buy a stainless xorst, should i buy one for a 16v or a williams?
If you use the Williams manifold you will also have to use the down pipe and cat or a Williams cat by pass pipe. The reason is that the Williams has a larger flange on the down pipe cat end, which will not bolt to your 16v cat.
Got down pipes and cats in stock s/hand.
