clio2 99 1.6 8v-clio2 00 1.6 16v
CLIO-Si
Car  1.6Si + 182
My first clio was the 8v which got written of as got crashed into passengers side cat c write off,i am buying back from insurers should be getting it back by friday,
Only reason im buying it back is that i found the 16v in the same colour and lower milliage,the 8v had full body kit,wheeels that were 550 brand new an had only been on the road for 2 months,twin 3" backbox s/s back to cat and the cat was new aswell,things like that i know can get put on my new car easy.
What im wondering is 8v to 16v is there much difference in
brakes-as all were new or near new
driveshafts-were new on less than 6 months
engine-i have some1 interested in cos its no use to me
i would like to get powersteering pump,abs sensors and rotors out of it also,
rear wheel bearing i need,can i use one of my old car?
Also anyone interested in other parts i havent mentioned might need a home?
the engines are completely different, not sure on which gear box they used in the 16v, brakes and such are the same iirc.
Brakes can be different need to check the 16V should have the bigger 259mm disks the 8v might have them.
Engines do share loads of bits
