Clock panel pushed inside
  clio182
Hi, while cleaning click screen I pushed one side of the panel in, the three adjustment buttons are still in place but a corner of the screen is pushed in. Any idea how to get it back into the frame. Is taking off the full dashboard only way?
Many thanks
Top dash will need to come off which is only a 10 minute job. You might be able to roll some sellotape around your fingers - sticky side out and use that to try and pull it towards you?
Many thanks
If you're referring to the plastic covering the dials (not sure you are) I just used a satnav suction mount on mine. Gently place it on the plastic, lock it to provide suction then give it a gentle pull. Hope this helps :)
Hi, just the LCD screen showing time and radio stations is pushed in. I will try to use some sturdy wire ans tried suction pull but not much space to get the pull. Full dash removal is big task.
cheers
