Clunking noise on/off throttle
Car  clio sport cup
Hi.. I have had my car for a while now a x 172, and its just started to clunk when i go on/off the throttle in most gears. It seems linked to the gearbox linkage into the gearbox, there is also a small bit of oil dripping off the rubber bit that connects the gearstick to the box?
It only does this when in gear.
Anyone else had this.? gearbox issues/engine mounts? If so can you see the engine mounts? back ones? I just found this site while searching, hopefully stop Renault taking the piss,
How do i change the rear mount?
car up on stands.. do i need to take the weight og the engine when i replace them?
